Pontiac 400 with T-5?
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
no it wont mount up, the pontiac has a different bolt pattern. i dont know if a company makes a custom bellhousing for your application or not. and no the stock t5 wount hold up to pontiac's tourqe. it would be easier to go with a TH350 or find a 200R4 out of a BOP. hope this helps
Wide Open Till You See God...Then Brake
Guest
Posts: n/a
It will mount up, you just need a different bellhousing. Thats really no big deal on a manual trans car... probably should have a better one than stock anyway. I saw more than a few Pontiacs at a car show a couple weeks ago with Tremecs, so I'm sure the T-5 will fit too.
BTW I wanted to add that the Pontiac engines always have lots of torque, so like said above it probably wont last and will eat a T-5 for breakfast.
[This message has been edited by madmax (edited June 03, 2001).]
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
400, bell, bellhousing, bellhousings, bolt, car, housing, make, motor, mount, pontiac, swap, t5, transmission, tremec
