Going from 305HO to 350 crate, which knock sensor?
Old May 31, 2001 | 02:08 AM
Like a ROC 89's Avatar
I am swapping in the GM performance parts 350HO engine in a 1986 Monte Carlo SS that originally came with the 305HO. I believe I need a knock sensor for a 350, but since there was never a 350 offered in the Monte Carlo SS in the '80 which do I use? What will work correctly with the original computer? Are all knock sensors compatible? Part numbers?
Old May 31, 2001 | 02:13 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
any knock sensor should work from a GM V8.i've heard that the 91-92 5.7 K/S's aren't as senative as some of the older ones.one of these should work.i could be wrong but i think all of the connectors are the same.i would take the K/S with you when you go to get the new one
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 2, 2001 | 11:35 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
You will also need a module for a 350, it is for the knock sensor. I lost all the info on this, so I don't know the part numbers anymore if I find it I will post it.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Jun 2, 2001 | 03:41 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Or you can run an LT4 KS (~$40), like me. Appearently there are three designs of KS: 305 (all indunctions), 350 (TBI, TPI and LT1) and LT4 (has a unique part number). I don't remember the part number though, but this is what came up (IIRC) in the GM computer when I was looking for a KS at the dealer.
George P. Lara
1984 Z28
SCCA, SCFB, SC3GFB
Old Jun 2, 2001 | 08:15 PM
Why the LT4 knock sensor? Is that the only one that will work with the stock computer in the 1986 Monte Carlo SS?
Old Jun 2, 2001 | 11:02 PM
steve8586iroc's Avatar
When I was ordering some parts from SDPC I asked the guy I was talking to about a K/S for my 350 that will replace my 305tbi and he asked one of the service techs witch one I needed, well all the service tech said was that I needed the one to match the ecm I'll be using. I also ask a freind who worked at a GM dealership and he said the same thing. I wish I had some concreet evidence on which one is right. Doesn't matter or change K/S and matching module.
Steve
[This message has been edited by steve8586iroc (edited June 02, 2001).]
Old Jun 3, 2001 | 05:52 PM
JPrevost's Avatar
Car: 91 Red Sled
I have that same engine now. I just asked for a knock sensor for a truck that had vortec heads, 96 c/k pickup. It was that easy, they pulled the part off the shelf and gave it to me. It works .
, Jon (350 TBI!)
91 Red My website
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
