Using thirdgen rad. when swap in LT1
Old Jun 2, 2001 | 10:06 AM
UnderDogRS's Avatar
i can use a 3 row Rad. that i have in my thirdgen when i swap in my 94 LT1 w/ Trans.
tia,
RS
<A HREF="http://ca.geocities.com/zander0710/" TARGET=_blank>
1992 Camaro RS</A>
Next Mod's
3.42/3.73 gears
SLP POSI
2800 stall converter
TransGo shiftkit
Best Time: (old times)
15.279@89.02MPH
Underdog Racing
Old Jun 3, 2001 | 02:05 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
yes however you'll either need special fabbed hoses or a 94 corvette accessory drive system the corvette system matches up perfectly even the radiator hoses match
Old Jun 3, 2001 | 02:06 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
yes however you'll either need special fabbed hoses or a 94 corvette accessory drive system the corvette system matches up perfectly even the radiator hoses match and no clearance issues with the ac cause it's on the drivers side
87 trans am 350 aluminums heads,lt4 hot cam,slp runners,headers,y-pipe,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60'
Old Jun 4, 2001 | 08:20 PM
TexasLT1's Avatar
Car: '92 RS
use your stock radiator, I did, just go down to hilow or Napa and get some new radiator hose
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
