350 to a 383, few ?'s
Old May 31, 2001 | 01:02 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
OK
Let's say I have a brand new 350 engine block. I have a crank for a 383 stroker. I have 5.7" H-beam rods. And, I have 383 pistons.
What do I need done to the block? I know it needs to be bored, but do I have to clearance the block in any spots to stup the rods from hitting anything? And it's going to have a big cam with lost of lift, like .530 lift. Will the rods need to be machined to clear the lobes on the cam?
Anything else I need to know about this?
Old May 31, 2001 | 08:11 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Anyone? I know I'm not the first to do this, come on.
Old Jun 1, 2001 | 05:07 PM
TransAm383's Avatar
You absolutely need to get your block clearenced for the stroker crank. Any good amchine shop can do this for about $100. I honestly don't know about your cam question. I wouldn't think so though. My cam has .510 lift on the exhaust and Ive had no problem. Also theres folks running a lot bigger cams than ours and I've never heard anything about clearence problems. Hope I could help.
Old Jun 1, 2001 | 07:04 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Do a search on 383 in the tech, tpi, and motor swap sections, and you should get all the info you can stand.
Old Jun 4, 2001 | 09:05 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
if you could get one the new 1 piece cranks in the 383 crate engine it supposedly fits without clearancing the block it has a 3.80 stroke,which makes roughly 382 cu in without having to bore the new block 388 with a .30 over bore as for the cam you should be ok with the 5.7 inch rods
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60' 4SALE anyone want her?
Old Jun 5, 2001 | 08:47 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Really?! that would save me a WHOLE lotta time and money. I'm using the 1 piece rear main seal crank and block, thanks for the info!
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
