where to get a 350 short block
Old May 21, 2001 | 03:09 PM
AFRO IROC Z's Avatar
I want to put a 350 short block in my 87 305 tpi. I want to know where i can get a good short block from and for how much. In one of the other posts i saw something about different flywheels could someone explain this please. Also will 305 heads with some pocket and bowl porting & polishing and a three angle valve job work well. I know they won't flow as well a 350 heads but the compression ratio will be up a little and the valves will be unshrouded some. or am i just better off with some heads for a 350, which is more cost effective.thanks in advance
Old May 28, 2001 | 12:26 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
If you plan on continuing on building this car up and always wanting more power I would start with a new short block. Then work on building the rest of the car as you get money like I have been doing.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
Old Jun 5, 2001 | 12:24 PM
Can anyone help me, please??
Old Jun 5, 2001 | 09:23 PM
camaro6spd's Avatar
you have to look around, in newspapers, junkyards, Treasure Hunters etc. Just make sure the block was not abused. Usally around 350 for a longblock.
Old Jun 5, 2001 | 10:02 PM
drt-rcr's Avatar
If you really want one in a hurry, most auto parts stores like autozone and advance sell short and long blocks. Since you don't have the same engine to swap in you will probably lose your core charge. I just priced a couple long blocks at autozone last week. An 86 and up long block (one piece rear seal) was $999. and an 85 and older was $699. I would think an old style 350 short block could be had for about $500 plus core charge.
Good Luck
anesthes
Mar 10, 2016 10:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
