Anyone ever run a 383ci with the counter balance adapter & 158 tooth flexplate?
Old Jun 6, 2001 | 11:01 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I just swapped my 305 for a 383roller setup. Has anyone ever tried a counter weight adapter that can be used to turn a stock (15? - 168 tooth) neutral flex plate into a 400sb style flex plate?
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old Jun 6, 2001 | 11:23 PM
drt-rcr's Avatar
Prior to going to the forged cranks, I ran the balance plates on stock 400 cranks with the small flexplate for several years in my dirt cars. As long as it's all balanced together there's nothing wrong with them. I ran for five years before going to forged cranks and never had a failure of the stock 400 crank. All engines were over 550 HP on alcohol and turned 7000 every night of racing.
As I said balance it all together and you won't have a problem.
Later,,, drt-rcr
I think its a 153 tooth and the big one is 168 tooth
Old Jun 7, 2001 | 01:06 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
hey, do you have pics of your tramaro, i would really like to see how it looks. my email is liljayV10@aol.com if you wanna shoot them to me. thanks
Wide Open Till You See God...Then Brake
Old Jun 7, 2001 | 08:05 AM
86Tra/maro's Avatar
no pic yet,sorry
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Elliswon
Aug 10, 2015 12:33 PM
gwade12
Aug 8, 2015 08:17 AM
