where can I find it?
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
if GM doesnt make the L98 anymore where can I get NEW engine that I can bolt up my TPI intake to. I want a NEW L98 350...I wish someone made it.
1986 Trans Am, T-Top, 305 TPI, Flowmaster 80 series. Much more to come in July.
[*]Sound System: Dual 12" Ground Zero Nuclear Series 900 watt RMS subs in custom box made to fit the rear well, Only 500 watts running them though, Pioneer Head Unit and Rockford Fosgate wiring.
AOL screen name= madbiker1
I want something that my headers, and TPI, and all that stuff will bolt rite up to, or will that all bolt rite up to a diff. 350
every thing will bolt up to a new and different 350 but i dont know if it will bolt up to a new one with vortec heads i do not think that will work. but you can reuse just about every thing on the old engine things that was on it and some things such as the water pump and oil pan, etc. i am in the begining stages of an engine swap form a 305 to a 350 and i can use a lot of little parts of the 305 for the 350
Transmission: 4L80E/4L80E
This thread is the closest I've seen:
https://www.thirdgen.org/messgboard/...ML/001100.html
rsilver had a few words to say about it...
Edit: You have an '86, so your TPI manifold won't bolt directly to it. Elongate the holes or get an '87-later manifold.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
[This message has been edited by five7kid (edited June 11, 2001).]
MikkoV
Sep 9, 2015 04:25 PM
Street Lethal
Sep 7, 2015 01:09 PM
