LT1 in 90 RS
Old Jun 10, 2001 | 01:40 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
LT1 in 90 RS
I did a search on this topic and found some interesting info on the topic. First off I have the motor already so no going back now and the 305 TBI is gone. I have a few questions that i hope those of you who have done the swap can answer.
1. What motor mounts-what to use 305 TBI or 350 LT1 and they need moved back right?
2. What wires need to be retained from the factory wiring harness (305). I dont want to buy a wiring harness so my dad and i are going to put the two together.
3. If i buy slp headers can i use their y-pipe or do i need to fabricate one?
4. Where did you put the computer at?
5. I am keeping the AC so what line has everyone used who has done the swap from what car did you get the lines?
thanks in advance ricky neff
check out my site: <A HREF="http://www.geocities.com/joecool_2u" TARGET=_blank>
</A>
Project LT1 install has begun.
[This message has been edited by rickyzZ28 (edited June 10, 2001).]
Old Jun 11, 2001 | 01:28 PM
rickyzZ28's Avatar
Car: 1990 RS
someone has done this swap please help me out.
ricky neff
</A>
Old Jun 11, 2001 | 05:59 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
<font face="Verdana, Arial" size="2">Originally posted by rickyzZ28:
</font>
Well you should have been able to find all of that in the other posts by us but here ya go: the mount you need to modify it slightly to brace the back of the a/c pump on the passenger side, use the stock mounts and the engine stays in the same place, go to www.hpsalvage.com there are pics and directions on modding the mount, the SLP headers and y pipe will work fine, get the 1 3/4", you will also need to beat up the crossmember to clear the a/c pump, as far as wiring im too impatient to figure out the wires so i ordered the painless wiring engine harness.
86 Z28, 93 LT1 swap in progress:
93 LT1
T5
Edelbrock Catback
Soon to come: Turbo and intercooler.
Old Jun 12, 2001 | 11:58 AM
Badas.sbird's Avatar
Car: 1988 GTA
Engine: 404ci LS2
Transmission: 700R4 Full Manual Reverse
Axle/Gears: 3.91 Australian 9 Bolt
Yes any exhaust made for your year Camaro will fit. I did all the wiring myself and it wasnt that bad with the help of the factory service manual. Stock mounts are a must due to the exhaust. The A/C will more than likely require you to noych the frame for clearance or to relocate the pump itself.
88' GTA w/ 93'Corvette LT1 absolutely bone stock
-4,000 stall
-Custom Fabricated"True"Ram Air
-200 shot NX Express
-Southside Machine Lift Bar and Subframe Kit
-11.43 in the 1/4 at 119mph with a 60ft of 1.59 seconds
-488 RWHP and 526Torque
-566 Flywheel HP and 610 LB/FT Torque at the Flywheel
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
