How hard is this?
How hard is this?
I have found a 5.7 liter 350 TPI out of a 89 Trans Am. How hard would it be to put it into my 92 Firebird with a 5.0 liter 305 TBI?
Also what would I need to pull out of the 89 along with the engine?
Transmission: 4L80E/4L80E
Pull out everything attached to the intake - air inlet & filter, harnesses, fuel lines, throttle cables, distributor, sensors, etc.
Then crawl inside and pull the ECM. You'll be inside there anyway to get the engine-to-ECM harness disconnected at the pass-through.
Don't cut anything!
Then jack it up in back and drop the tank to get the fuel pump.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Don't cut anything!
RedLeader289
May 28, 2019 01:47 PM
