Question about swapping
Old Jul 8, 2001 | 11:35 PM
87CamaroChris's Avatar
Car: 1987 Camaro
Engine: 305 LG4 Carb. (no ECM)
Transmission: TH700-R4
I may be able to get ahold of a Chevy 302, but I was wondering what all would I have to change for it to fit in my car?? (eg. Would I have to change the driveshaft, tranny, motor mounts, etc.)
1987 Camaro Sport Coupe
305ci 4bbl (LG4)
3.23 Gears
THM 700-R4 Automatic Transmission
All Stock
Old Jul 9, 2001 | 10:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Assuming you're talking about a '67-'69 Camaro Z28 302, the dipstick will be driver's side and the crank will be two-piece rear main seal design.
Details like water pump length may be different, but your '87 part will bolt up to it. The driveshaft, tranny & motor mounts will bolt right up as well. If it really is an old Z28 302, your bigger issues are going to be how to make that rev-loving beast happy in your 3rd gen with its automatic, highway gears, etc. What were you planning on doing for induction?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 9, 2001 | 12:51 PM
Car: 1987 Camaro
Just found out some more on the old 302 and how they like to rev high and require high octane gas. I think I might go with a 350 or 383 instead, but thanks for the reply.
305ci 4bbl (LG4)
3.23 Gears
All Stock
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
