v6 to 327
Old Jan 3, 2010 | 03:24 PM
86 firebird's Avatar
Car: 86 firebird
Engine: v6...for now i want a 350
v6 to 327
hi i have an 86 firebird and it has the 2.8l v6 and i want to put my 327 and auto tranny into the car, i am having trouble with finding parts and straight answers.
do i need thicker front springs? i hear yes and no(car will be my dd)
ware can i get frame mounts for a v8
will the rearend hold up?(im not going to be nice to it, im 16)
Old Jan 3, 2010 | 04:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: v6 to 327
Stock front springs are fine. I ran V6 front springs in my BBC car for years. A heavier spring rate will keep the nose up during hard cornering or braking.
You could pull the frame mounts from any junkyard car or just buy a set from the dealer or aftermarket.
Your 10 bolt diff is the same no matter what engine is in the car. The tiny 7.5" ring gear can be broken by a street car and has survived dragstrip use from a big block powered car. I doubt your 327 will cause much harm but that doesn't mean you still can't break the teeth off the ring or pinion.
Old Jan 3, 2010 | 04:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
86, welcome to thirdgen.org.
Now, read the "V6 to V8 swap" sticky in the top section of this forum.
Old Jan 3, 2010 | 09:30 PM
Car: 86 firebird
Re: v6 to 327
sweet thanks for the help. i know how to do it all its just the things i have been told may break or need changed and i wanted straght answers insted of "i think".
so thanks agen for your guy's help and i think that dubble hump 327 will be a ball in that car
84 TA NV
Sep 6, 2015 08:02 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hayesaw0210
Aug 23, 2015 11:15 PM
92zeddar
Aug 26, 2001 08:19 PM
JC88Camaro
Sep 22, 2000 12:55 AM
