engine blocks, what does these numbers mean and how old are they?
Old Jul 12, 2001 | 11:00 AM
iroc111's Avatar
if anyone out there have this info. let me know. thanks!
engine 1: bottom rear GM 5.7L, E031
top rear: 14093638
each side: 638
in front: 627,613
engine 2: top front: 557752-3B
front also: B23-790
rear: 751-2 & F10
one side: 350
Old Jul 12, 2001 | 11:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks like a 350 block cast May 3 of a year ending in 1 (would be 91 in this case); probably a roller block
ICON Motorsports
Old Jul 12, 2001 | 12:13 PM
iroc111's Avatar
for the first engine, correct but how about the second one I believe its an Olds. block
thanks
Old Jul 12, 2001 | 04:48 PM
regs327ta's Avatar
buy yourself an interchange manual ($20) I did and found that I had hit a gold mine. I bought a 1985 T/A for $800 the guy said he threw a 350 in it I just found out it is a large journal 327 (which made more sense out of the 2000 and up power range.) plus they will tell you more golden information than websters.
Old Jul 12, 2001 | 06:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Large journal 327 and 350 both use the same block... both have 4" bore and will accept either crank. You can't tell which one it is by the block number.
#2's numbers mean absolutely nothing to me, it could be anything. It would help if you can identify the mfr. Post some other details like distributor location, whether the crank is up in the block rather than "on teh surface" so to speak like Chevy motors are, fuel pump location, etc.
ICON Motorsports
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
