what flex plate to use on 383?
Old Jan 6, 2010 | 01:59 PM
siduramaxde's Avatar
Car: 86 berlinetta
Engine: 383
Transmission: built 700r4
Axle/Gears: 3.42 zexel torsen
I have a 383 that is externally balanced and it came with a 168 tooth flexplate. Do I need a 153 tooth externally balanced flexplate for a 400 crank? I want to use the stock starter that came on my 86 camaro and I will be using a 700r4 trans. The car came with a 153 tooth flexplate on a 5.0 LG4.
Anyone know what flexplate will work? Part #????
Thanks.
Old Jan 6, 2010 | 02:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: what flex plate to use on 383?
Yes, that will probably work.
Old Jan 6, 2010 | 02:44 PM
Car: 86 berlinetta
Engine: 383
Do you know of one that will for sure work
Old Jan 6, 2010 | 03:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If your 383 is a 2-piece rear main seal externally balanced set-up, a 153-tooth flexplate for a 400 crank will work with your engine and stock starter.
Old Jan 7, 2010 | 12:25 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
What transmission are you using? Do you know what year of block it is? The reason I ask this is it will determine what starter you use.
In the past depending on those things you would have to drill/tap the block to get the correct starter to work. However I did find out you can use a starter off a 99 chevy truck and it has the correct bolt pattern, the correct offset for the 400 flywheel and the smaller nose cone to fit inside the 700R4 bellhousing. It's one of the good things GM did for us.
Old Jan 9, 2010 | 02:02 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Axle/Gears: 4.11, 9inch
i used a 1 piece block on my 383 and the 153 tooth flexplate off my 305 would have worked but i had to buy a new starter cause it wouldnt turn over the new motor any way (high Compression) so i used the 168 tooth.
just sum more food for thought.
codeysabatini
Nov 10, 2015 04:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
JSDaddy189
Sep 26, 2015 03:50 PM
