350 swap, help!
Old Jul 23, 2001 | 08:48 PM
billyde's Avatar
350 swap, help!
I'm in TX, what should the total cost be to swap in a goodwrench 350 (about $1300 as advertised)including the fee to install it. Scoggin-Dickey is up north in Dallas I think. I currently have a well running 305 in there so it should just be a "drop in".
Old Jul 24, 2001 | 03:36 PM
Hanks1's Avatar
a shop would probably charge 10-12 hours labor plus what everelse needs to be swapped like water pump/alternator/ac/ps/intake and fuel injection
84 Z28
78,000 miles
1970 350 ci 4 bolt chevy motor punched .030 over to a 355
stock 1970 heads with 1.94's and very mild porting
edelbrock rpm cam,intake, 750 4barrel
weisco 9.6/1 pistons & rings
edelbrock headers and catback (without the cat)
700r4 trans
3.23 rear (no posi yet)
Old Jul 26, 2001 | 11:01 AM
84TransAm's Avatar
Almost everything from the 305 swaps right over. There's only a few things you need that are different. A 350 Harmonic balancer is needed, and a 350 dipstick, the 305 hits the crankshaft. That's really all you need. I would highly recommend getting a good aftermarket intake and headers and installing those before the engine goes in.
The engine puts out 239 hp and 304 ft-lbs of torque with the LG4 intake and exhaust manifolds, and bumps up to 265 hp and 350 ft-lbs of torque. For someone to install, expect it to cost roughly $700
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
350 ready to get in and run as soon as i find a WC T5.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
