required manifold vacuum
Car: '89 Firebird
Engine: 7.0L
How much manifold vacuum is needed to operate power brakes? I'm looking at a thumper cam and I need to know what are my limits. Nobody on the Brakes board answered this question.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I've heard, and read, that anything below 14in/Hg is gonna start to show. A long time ago, I had a 74 Camaro, 400cid/TH400 that had a solid cam (can't remember the specs) and it pulled about 12.5. It was fine when you first came up to a stop and just sat there. But if I got into stop and go traffic, I had no stop and all go.
It was time to put it in Neutral.
If you have problems, buy a vacuum canister and hook it up soley to the brakes. It'll help, but it won't totally fix it. In a lot of stop and go traffic, it'll loose it's suction, just not as fast as the power brake booster.
Hope this helps.
AJ
It was time to put it in Neutral.If you have problems, buy a vacuum canister and hook it up soley to the brakes. It'll help, but it won't totally fix it. In a lot of stop and go traffic, it'll loose it's suction, just not as fast as the power brake booster.
Hope this helps.
AJ
I have been wondering this myself.
What kind of duration and lift will get you around 14in/hg?
89 RS 350 TBI auto Hooker SC/LT headers Open element 3in K&N CVT protorque mini-starter
Daily driver 91 RS auto LO3 63k
New project- 89 Formula 350 WS6
383 or 400 to come!
383 or 400 to come!
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
