diffrence between tpi block?
Old Jan 13, 2010 | 01:47 PM
sd88formula's Avatar
Car: 1888 firebird formula
Engine: 350ci 5.7L tpi
Transmission: 5 speed
Axle/Gears: 12 bolt posi track
whats the diffrence between a tbi and tpi block coul you put a tbi block in a firebird and just change intake to tpi only thing i have noticed it dont have the roller/hydrulic cam/lifters besides that would it run the same or ruin the motor?
Old Jan 13, 2010 | 05:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you're talking about LO3 vs. LB9, they are identical. The cams were different, but that's not the "block".
If you're talking about LO5 vs. L98, the truck LO5's didn't get roller lifters, but the block casting was the same. Also had larger dish in the pistons. Passenger car LO5's I believe were identical to L98 except for the cam, but that's not the "block".
Bottom line: Nothing "special" about TPI blocks vs. TBI.
evilstuie
Jan 9, 2020 08:29 PM
lakeffect2
Aug 23, 2015 08:44 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
