383 into a 92 Camaro
Old Aug 5, 2001 | 04:30 PM
jamesbern's Avatar
I am currently building a 383 for my 92 tbi Camaro, the dyno figures on an identical engine are as follows 450 horse and 470 ft/lbs. torque. I am rebuilding my 4L60 to hold up to this beast, but will my rearend hold up during everday use until I can order my 12 bolt? Besides the fuel pump and regulator, what do I need to do to perform this swap? If I disconnect the ECM what will stop working, I want the wirng harness and computer for the 51 GMC pickup I am also building. I imagine subframe connectors are a definite must have. Wiring the fan and ignition system should be little trouble, but what about the passkey? Let me know what I am forgetting if anything, please.
Old Aug 5, 2001 | 06:52 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i've been using my stock rear for almost 3 years. i'm not trying to do wheel stands either.you're going to have to do some stiffening is you want to put that power to the groung
86 camaro 405 sm. blk. th 350 tranny 3.42 gears
Old Aug 5, 2001 | 09:40 PM
jamesbern's Avatar
Yea, I realize that, but I'm not to worried about that yet. As long as it will hold together for a few months. Anybody on a budget will understand you can only do so much at one time. Basically, I just want to know all of the problems I might run into on the engine swap. I appreciate your response as it settles my mind on the rearend issue. Thanks!!!!!
Old Aug 6, 2001 | 04:37 PM
GTARob's Avatar
If you search the archives for my name you will eventually run into my ravings about my own engine swap. I had numerous annoyances that noone could have foreseen, as I am sure you will as well. Look for the particularly funny "Lesson in fire safety" post. As for the rear end, It will hold up just fine as long as you stay on street tires and lay off the gas pedal. I haven't done the latter and it mine is still fine though. Go to slicks and put the full brunt force of the motor to the rearend and it will move while your car stays still if you get my meaning. As for disconnecting the ECM, if you do that then the car won't run. For the time being I am still running with my stock(305)chip and the only prob I have had is running very rich. The engine still won't get traction all the way through 2nd gear but is still nowhere near its potential. Running with the stock ecm will be ok for a bit. You need to change the ESC and the knock sensor to ones for a 350.
Robert
1989 GTA TRANS AM
Was a TPI 305 & t-5 car.
Is now 383 stroker w/ the same T-5
World products Sportsman II heads(64cc fast burns). Lunati pistons@10.5:1 and 452/462/112* camshaft. Eagle crank and 6 inch rods. Ported/polished/port matched stock TPI intake. T-5 on a suicide mission.
Old Aug 6, 2001 | 06:23 PM
craig's Avatar
Car: 86 camaro
if you're going the carb route i can help. on my 86 the computer wiring harness came thru the passenger side fenderwell. the dist., starter wiring came thru the firewall.i put my fan on a toggle switch. any particular questions i can answer feel free to email me
Old Aug 6, 2001 | 06:58 PM
87RS402's Avatar
I changed my 86 to carb also. I solved the fan issue by using an independant relay that is self contained. It has it's own temp sensor and harness that is very simple to install. I paid $36 for mine at Schucks. Only took about 20 min to put it in and wire up.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
toronto formula
Nov 10, 2015 06:17 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
