What type block will take TPI?
Old Jan 18, 2010 | 07:54 PM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
My 1989 Formula 350 has 150k miles and cracks in the block which are at least temporarily plugged with the red devil stuff. I'd like to go ahead and try to build a new engine to be ready for the eventual demise of my 350. My question is after reading so many different post what do I have to look for when looking at a block to build on? Can I use any 350 block and build up from that and put the tpi intake on it? I know if I go with a crate engine my choices are somewhat limited. I really want to stick with the tpi because I have owned one for so long I have the thing down pat pretty much.
Thanks for any help.
Old Jan 18, 2010 | 08:04 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: What type block will take TPI?
Any SBC should accept TPI just fine. Anything using a Vortec style head will require a Vortec TPI intake manifold as the bolt pattern was changed on the Vortec style heads.
Old Jan 18, 2010 | 08:06 PM
Twin_Turbo's Avatar
not only the bolt pattern, more importantly the port is located higher
Old Jan 18, 2010 | 08:23 PM
megtom2's Avatar
Engine: 350 tpi
Transmission: 700
So any block is usable with the heads and all of the other things bolted into my current stock 350 tpi engine?
Old Jan 18, 2010 | 08:28 PM
87WS6's Avatar
Any Chevy SBC is. The LT1, LS1, LS2 etc. won't be TPI compatible.
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
