Help on 350 build up. Questions
Old Jul 28, 2001 | 06:16 PM
leirch's Avatar
Guys,
Have the car in the Signature obviously, it has VERY low compression, from 100psi to 120psi, consistant on all cylinders. The car runs pretty well still BUT has a miss and its driving me nuts, along with less than optimal performance. I have been trying to find an identical 350block like I have so I can get it assembled and ready to put my heads/cam into it.
Now, I'm looking to find a block that probly needs bored .030 over and the usual rebuild. What would you guys estimate a rebuild would cost? I'd like to use a stock crank, and maybe different rods/pistons(NEW). I'd like to be able to take the car to 6500rpms, I shift it at 6000 right now and it seems to hold up just fine.
What parts would you recommend?
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 29, 2001 | 12:24 AM
leirch's Avatar
Ok, I've determined that I'm going to use my current crank.
I don't know the condition of the block right now, I'm assuming its the standard bore, I'm thinking .030 over, new pistons, connecting rods, rings, and arp bolts.
Could I get some brand/part number suggestions?? As to which parts people have had luck with and/or like?
Thanks,
Brendan
Old Aug 7, 2001 | 10:04 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
30 over bore and new pistons are esential.
83 berlinetta currently 350/350 3:42 gear,2500 stal,3inch exhaust,2 1/4
exhaust manifolds,comp cam 268,performer intake
L69 dual snorkle aircleaner 3160lb
Old Aug 14, 2001 | 01:25 AM
BringBackThe80s's Avatar
"Now, I'm looking to find a block that probly needs bored .030 over and the usual rebuild. What would you guys estimate a rebuild would cost?"
When budgeting my rebuild, I didn't factor in all the "cheap" parts (bearings, oil pump, etc) This stuff really adds up quick. Also, machine work will be one of your biggest expenses, depending on what you have done. I'm already way over what I planned on spending, and havn't even gotten to the heads yet. So far, I've got the rotating assy complete, Cam and lifters, oil pump, timing chain and gears. Counting machine work, I'm in over 1100 bucks, and haven't even gotten to the heads yet. Folks tried to me it was just as cheap to go with a ZZ4, and I'm beginning to believe its true.....have fun!!
Old Aug 14, 2001 | 02:35 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Bore/hone $90, install freeze plugs, cam bearings $45, tap passages for plugs $10, press old pistons off new ones on $35.
I recommend Keith Black pistons, they're beutiful for the price... And the Summit kit could be had with forged if you want, or you could get the kit w/o pistons ($230 or so) and it comes with all federal mogul stuff and brass plugs.
Old Aug 14, 2001 | 07:05 AM
El Guapo's Avatar
Crate engine is the way to go
Clayton
Old Aug 14, 2001 | 08:58 AM
GeneralGrant's Avatar
Can you use tpi with a zz4 and what kinda milage do you get with it?
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reborn756
Sep 4, 2015 03:42 AM
redmaroz
Aug 16, 2015 11:40 PM
