Again, TPI to Carb..search done.
Old Aug 3, 2001 | 08:51 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Okay, the search netted 157 matches, but I still have some questions. I have the VATS with the little chip in the key. If I remove the TPI harness, and ECM, will this affect the VATS, will I still be able to start my car? I still don't understand the fuel pump relay/ oil pressure switch deal. THis is a 91Z, where is the relay, and can I bypass the oil switch w/o going to mech. gauge?
For the pro TPI guys, this will eventualy be a full on drag car, so the carb is better for my situation in my opinion. I don't want to cut and hack up the harness, or as little as possible so I may go back to TPI later if need be. (No emissions testing yet)I am starting on this swap this weekend, so any and all help would be most appreciated. If you feel the need to flame, fine, I have done my share. Its about time I get some back. But I do need real info also.
Thanks,
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Old Aug 15, 2001 | 05:00 PM
mat89RS's Avatar
you will be able to start you car. the vats only tell your TPI ecm to turn the injectors "on" and fuel ump on and also starter enable relay. you will need to rewire your starter solenoid.
LT1 POWERED
HEADMANS HEADERS
NEARLY 300 HP.
next mods:
crane roller rockers 1.6
lt4 hotcam kit
airfoil
58MM edelbrock trottle body
new paint (wet look blue)
17' rims with 275 zr 40 and 245 zr40
Street Lethal
Apr 30, 2019 12:14 PM
skip91
Sep 24, 2015 03:29 PM
Mutillator
Sep 17, 2015 04:38 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
Sanjay
Aug 12, 2015 03:41 PM
