What engine?
Old Aug 14, 2001 | 05:40 PM
1990CamaroRS's Avatar
What engine?
what engine would give me the most power in my 1990 RS V8 auto?
Old Aug 14, 2001 | 08:36 PM
firbird's Avatar
you want hp lots of hp 540 big block
Old Aug 14, 2001 | 08:37 PM
firbird's Avatar
oh yea and blown
Old Aug 14, 2001 | 08:53 PM
wou i be able to put this one in?
http://www.speedomotive.com/540_sportmaster.htm
Old Aug 14, 2001 | 08:57 PM
BTW does anyone know what the guidlines are for street legal car in Connecticut
Old Aug 15, 2001 | 12:28 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Dude, not to flame, but your question is too broad, vague, and starry-eyed. A more appropriate question would be, "How can I build an engine for street-legal, emissions-compatible power?" Even that is a little too broad, vague, and starry-eyed.
First, answer your last question by checking with your local authorities. You're likely to get answers like "Keep it factory." But, if you need to go through emissions, check with people who conduct the inspections/tests. "Street-legal", beyond emissions, typically means "safe" - brakes, lights, mufflers, etc.
In general, you can upgrade with emissions-legal parts like headers and cat-back, cam, & intake with no effect on emissions or street-legality. If you have a 305, a 350 put together like factory 350 TPI engines would also fit those catagories. Power-adders like nitrous will give a good boost in power without touching emissions parts.
Or, you can go the "stealth" route and put on parts that look similar to stock, will pass sniffer tests, but aren't technically certified as smog-legal replacements. 383 stroker motors fall in that catagory, for instance.
Look over posts on these boards, including the Tech & TPI/TBI forums, do some homework, and you can ask more specific questions that won't get snide answers like firbird gave you.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 15, 2001 | 05:19 PM
thanks for the bit of advice five7 i appreciate it i will look into those things thanx again
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
