LG4 to 400 swap ??'s
I'm in the process of building a 400 to replace my tired old LG4 in my 85 Z28. I understand the the ECM controls the carb, distributor advance, and torque converter lockup. The new setup will have a Holley Carb and Vacuum Advance distibutor. Will the ECM still control torque converter lockup, or is another modification required? Also, with the engine swap comes a 10" torque converter, so how will that effect the mix?
Transmission: 4L80E/4L80E
The ECM will go into brain lock without the carb and distributor input, so - no, it will no longer lock up your TCC. You need a kit from Summit/Jegs.
The 400 is externally balanced, and such flexplates typically are 168 tooth rather than 153 tooth. Starter problems. Usually solved by a mini.
As long as the torque converter bolts to the flexplate and is matched to your engine (mostly the cam), it will be fine. 10" will probably stall pretty high, though.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
ambainb
Apr 25, 2016 09:21 PM
