Someone make a damn LS1 swap kit!
Old Aug 14, 2001 | 06:59 PM
Richard De Jonsano's Avatar
Car: 1990 IROC-Z
Engine: 377 4BBL
Please!!!!!!!
Old Aug 14, 2001 | 09:50 PM
Guest
Guest
Posts: n/a
I fail to see the point of this post.
Old Aug 14, 2001 | 11:00 PM
jharms's Avatar
Are you wanting to swap out your LS1 to something else, or what? You're not being very clear...
Old Aug 15, 2001 | 02:27 AM
Car: 1990 IROC-Z
Engine: 377 4BBL
Just saying someone needs to make a kit to swap an LS1 into a 3rdgen.
Old Aug 15, 2001 | 10:48 AM
Guest
Guest
Posts: n/a
I am 99% sure the people here are DIY guys, not fab shop owners. Call Lingenfelter, I'm sure he'll make up a kit for you.
Old Aug 15, 2001 | 04:10 PM
mat89RS's Avatar
there's no kit available to do so (that I know). you'll have to get someone to do your wiring harness or if you thing you're able to, well then go ahead. these are pretty hard to install from what I've heard.
Old Aug 15, 2001 | 04:35 PM
Car: 1990 IROC-Z
Engine: 377 4BBL
<font face="Verdana, Arial" size="2">Originally posted by madmax:
I am 99% sure the people here are DIY guys, not fab shop owners. Call Lingenfelter, I'm sure he'll make up a kit for you.</font>
Ok I'll call Lingenfelter.
Old Aug 16, 2001 | 05:53 PM
89ProchargedROC's Avatar
guy i know up in wisconsin threw in a LS1 in his yellow Iroc-z
he even has a webpage documenting things, look it up
Old Aug 17, 2001 | 04:02 PM
candyman's Avatar
you might also check out
www.jagsthatrun.com they could probably help you out.
this guy swapped an ls1 into his 3rd gen...all custom fab though
www.fbody.com/members/bradkiel/index.htm
Old Aug 20, 2001 | 12:17 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
I know it's not f-body related, but there is a guy over on the g-body.org maling list who is swapping an ls1/t56 combo into his 88 monte carlo ss.
http://home.earthlink.net/%7Ebzdel/LS1swap.htm
or try www.geocities.com/ls1montecarloss/
this looks totally kickin for a swap, but much time consuming
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
reiderz iroc
Aug 13, 2015 04:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
