f-body 350HO from sdpc2000.com
Car: 2002 Z28
Within the next year i am planning to do an 305-350TBI swap. I was looking at the 350HO engine for f-bodies at sdpc2000.com and was wondering how much horsepower this engine would produce with a Holley 670cfm TBI and an edelbrock performer intake(EGR) out of the crate. Also is it CA emissions legal, It does come with Edelbrock Aluminum heads and i know those are 50 state legal (EGR)
engine specs:
cam: 191/196 @ 0.050"- .414"/.429" lift
compression: 9 to 1
crank/stroke: LT4 Nodular 3.480"
GM PM rods
Pistons: Hyperutectic 4 Valve Relief flat top
block: 2 Bolt Main 1 pc Rear Seal
1990 TBI
engine specs:
compression: 9 to 1
GM PM rods
1990 TBI
Transmission: 4L80E/4L80E
Technically, it is not a legal replacement. For all practical purposes, it will pass visual if you have everything hooked up, and sniffer if everything works.
As for power, the cam is pretty lame and the compression pretty low. But, it will likely have a good bit more power than your 305 anyway.
A better cam, smaller chamber heads, headers and a good-flowing rest of the exhaust would make it run better, I'm sure, and still pass inspection/sniffer.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 1990 Chevrolet Camaro RS
Scoggin-Dickey will put a different cam in that engine for you, just ask. They also have that same engine with Edelbrock aluminum 60cc 2.02-1.6 Heads.
Car: 2002 Z28
where can i find a CA legal replacement 350 engine with between 275-300HP that will support a TBI, EGR and everything.
See above, except: "Technically, there is no legal replacement 350 for 3rd gens w/TBI..."
gixxer92
Apr 12, 2022 12:09 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
