I read the post about the ZZ4 and will it be legal?
Let's narrow down everything, please.
I also wanna swap my 305TPI for a ZZ4.
I wanna keep my "TPI", I mean I'm gonna put an aftermarket, big mouth intake. Combined with my SLP runners, ported plenum and a larger TB(52mm or 58mm) ad my mods(below)+ maybe larger headers.
Can all this be kept sniffer legal?
I know re-progaming(prom) is a must.
Also, Where is the best and cheapest place to buy a ZZ4?
Thanks in advance.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear.
Dealer instaled:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(50), Harwood fiberglass hood,Original GM "Notchback GTA" hatch.
Flowmaster 3" Cat-back exhaust,TB coolant bypass,B&M Ripper shifter, Centerforce dual friction clutch, Ported & Siamesed Plenum matched to SLP Runners, March Power/Amp Pulleys. (???HP)
DIRECT LINK TO PICS OF MY CAR. NO WEB-PAGE. http://community-2.webtv.net/MZavraz...A90/page9.html
five7kid
close
"Technically" legal? No. "Practically" legal? Yes.
You'll need to plumb exhaust up to the intake for the EGR valve since the ZZ4 heads don't have cross-over passages. The Big Mouth (Vette style) helps you there.
Larger headers would probably be a good idea to get the power out of it.
Couldn't say who's best for getting the engine itself. I'd think some comparison shopping is in order.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
The cheapest place to get a ZZ4 is the closest chevy dealer to you that has GMPP parts, (not all chevy dealers sell GMPP) due to shipping cost the one or two hundred buck tou may save by shopping around is not worth it.
I dont know anything about how strict tests are in NY as far as testing all you emmisions hardware but in NC I had no problem just turning the EGR off when you have the reprogram done and left it bolted on, it passes the test easy and they have no reason to go messing with the EGR.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
