400 build up questions
Old Sep 2, 2001 | 08:20 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
I am in the middle of building up a 400 SBC and had a few questions.
I am installing a Scat crank, Eagle H-beam rods 'floating', and JE pistons.
The rods are chamfered on the large end of the rod it self to indetify which way the rod sits on the crank journal. The rod bearings that I have are chamered as well. My question is how important is it that the bearings be chamfered like the rods?
What is the purpose of the chamfer on the rod and bearing? If I go and buy a standard set of rod bearings from a local parts store, there is no chamfer on them.
Old Sep 2, 2001 | 09:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
"Real" performance crankshafts have a big smooth radius ground into their journals where it meets the throw, to prevent stress concentration in that area. "Real" performance bearings have one side relieved to clear that. If you put regular replacement bearings into an engine with a properly ground racing crank, they will bind up from the edge of the bearing riding up on the radius and smashing the 2 rods on the one journal together.
ICON Motorsports
Old Sep 3, 2001 | 07:50 PM
CHCKLS's Avatar
Engine: 409 SR
Thanks, I was just curious about this.
camaro71633
Sep 1, 2015 10:24 AM
1985chevydude
Aug 20, 2015 12:29 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
