how much to put in a brand new 383 in a 89 camaro?
Old Sep 4, 2001 | 11:59 AM
liquidinferno's Avatar
self explanitory
89 IROC-Z 5.7L
bone stock for now...
Old Sep 4, 2001 | 01:53 PM
and how would i needto prep the chassis?
Old Sep 4, 2001 | 07:38 PM
kamaro90's Avatar
Someone reply to this ? I'm doing the same thing
Old Sep 4, 2001 | 09:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You prep the chassis by putting in subframe connectors and poly bushings, like those from Spohn above. Where you go from there depends upon how wild you go with the engine, or what exactly you plan on doing with the finished product.
The rest of the question is too open-ended to answer intelligently. It depends upon how much of a 383 you get (piston type, head type, induction type, etc.) and how complete it is (short or long block, externally balanced balancer & flywheel/flexplate, starter, etc.), what all you do to it (exhaust, induction, cam upgrades, for instance), how much you do yourself vs. have done, whether you're talking about a competent shop or some Tom, **** , or Harry, how much labor is in your area, etc., etc., etc.
To get in the ballpark, get a price on an engine from a place like PAW, then double it. It'll probably still be more, but at least you'll have some idea.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
