Need A Little Help Please
Old Apr 3, 2001 | 01:48 PM
HotRod455's Avatar
Hi, I am so excited. I just finished putting an 69' Olds 455 in my 86' camaro . The only thing is that the bar that comes from the rearend (I think it is called the Torsion Bar) is supposed to bolt to the tranny, well I now have a THM350 and there is no place to bolt the mount to? ANy suggestions.
Thanks, I appreciate any help.
Old Apr 3, 2001 | 05:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Summit & Jegs both have a bracket that can be bolted to the tailshaft housing. Spohn (ad above) has nice conversion pieces.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Apr 5, 2001 | 06:24 AM
HotRod455's Avatar
Thank You. I just so happen to have a Jegs mag sitting on the table I will look. I want to drive it again so much it's making me nuts. Thank you again.
Old Sep 2, 2001 | 09:31 AM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Hey, did you ever get that 455 Olds running in your camaro? I have one that I was considering installing and am curious how yours worked out. You didn't have a email address posted.
Old Sep 7, 2001 | 01:04 PM
slowV8berlinetta's Avatar
i've got an olds 455 sittin in the garage and have put considerable thought into that or a 403 olds. how does everything work out with headers and motormounts??? i need to know. If possible, email me @www.hipergp@aol.com
'84 Berlinetta, LG4, 700R-4, starwars interior, no major mods yet
Old Sep 7, 2001 | 01:22 PM
86Trans Am's Avatar
I'm curious too, as to how the swap went. My 86 ta will soon be powered by pontiac and i just want be aware of some of the bigger problems before i start
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
