Pulling a motor question - Swap experts please enter
Old Sep 12, 2001 | 10:08 AM
RED92's Avatar
I am swapping both the tranny and motor. Since the T56 is used, I plan to swap it first and keep the old engine for testing. I need to eliminate some variables from doing both swaps at the same time in case I have problems. My question is, will I have to take out the transmission again to put in my crate motor, or will I just need to undo the bell housing to motor bolts? Trying to eliminate duplicate work if I can.
Thanks in advance...Alex
Old Sep 12, 2001 | 10:51 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Just unbolt bellhousing from motor and pull motor mount bolts and pull it right out.
Old Sep 13, 2001 | 07:21 AM
RED92's Avatar
Wil lthe flywheel come out with the motor then?
Thanks...Alex
Old Sep 13, 2001 | 05:14 PM
zerogauge's Avatar
flywheel is bolted to the crank. torque converter is bolted to the flywheel.
torque converter slides into tranny.
so yes, the flywheel comes out with the motor, as well as the torque converter if you dont unbolt it.
Old Sep 13, 2001 | 06:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Uhhh, T56 - what torque converter?
The flywheel is bolted to the crank, the clutch is bolted to the flywheel. The T56 input shaft will slide out of the clutch.
Getting it back in will be a challenge, to be sure. It may be easier in the end to pull the tranny with the engine, split the engine/tranny while out, remount the tranny to the engine, and re-stab the engine/tranny together.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 13, 2001 | 08:34 PM
RED92's Avatar
five7kid-
You think I can do this with a basic engine hoist (with leveler) in my garage?
Alex
Old Sep 13, 2001 | 11:50 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Although I am not "five7kid" I will answer your question with a definite yes. Take your time and good job on obtaining an engine leveler.
Old Sep 14, 2001 | 07:26 AM
RED92's Avatar
86z/92rs -
Thanks...Alex
Old Sep 14, 2001 | 02:08 PM
five7kid's Avatar
The tilt sling (leveler) is a huge plus. I did my install w/auto attached in my garage with cherry picker/tilt sling. Doing so with a manual should be even easier.
Old Sep 14, 2001 | 02:52 PM
89bonestockiroc's Avatar
I just did the swap in my garage as well. I pulled them both together and mine was an auto, should be even easier with a manual.
Mike
Old Sep 14, 2001 | 03:23 PM
RED92's Avatar
Thanks guys, nice to hear mine is going to be a piece of cake...HAHAHA....
Alex
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
