aluminum intakes?
Old Sep 18, 2001 | 05:01 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
aluminum intakes?
i have a 305 out of an 86 berlinetta that i swapped into an elcamino andi was wondering about intakes. the 305 originally had an alluminum intake and is in good condition,it is stock. so will it make a difference to buy and edelbrock performer. if not i will clean up the stock one. the reason why i am asking is cuz it is stock. so would that make a difference since it is alluminum?
Old Sep 18, 2001 | 06:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
See https://www.thirdgen.org/messgboard/...ML/000961.html on the carb board.
The Performer, or an Action +, or the GMPP intake like I have, are probably better pieces. The question is if it will make any difference.
The answer is, probably not enough to make it worth it unless you do other things as well.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
