Unfortunately, I think I am going to have to do it. Ford -> Pontiac
Old Jul 13, 2010 | 09:20 PM
  #51
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Re: Unfortunately, I think I am going to have to do it. Ford -> Pontiac
Installed C5 brakes, eradispeed rotors, and braided steel lines with Ed's brackets.
Old Aug 10, 2010 | 12:01 AM
  #52
Andrew91GT's Avatar
Car: 1990 formula
Got my machined engine parts from Watt, been assembling in my garage, figured I'd post up some pics.
Aluminum block, 4.151" bore, 4" stroke.
Prepping the thrust bearing on a granite block
More thrust prep, scotchbriting the bearings. Nice crosshatch pattern.
Oiling mod to oil the major thrust surface of the crank so the crank will live while the motor is building boost on the transbrake
All the main bearings done
leftover ring filings. Sure took a long time to file all those rings!
The block. A little cap walk, but it's an old block and has seen many rebuilds. Well seasoned! 4 bolt splayed Cleveland mains, roller cam bearings, bronze lifter bushings.
4" stroke lunati pro series crank. Gun drilled mains, gun drilled crank pins, contoured knife edged counterweights, internally balanced for some serious rpm!
Crank sitting in the block.
Mains torqued to 90/70 with ARP moly lube.
Old Aug 10, 2010 | 07:09 PM
  #53
stoning_volcom's Avatar
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
its crazy cause i was at the shop this morning wondering if anyone has or is tryin to put a ford motor into a pontiac, like the ls1 into the mustang lol kinda cool. I like the look of a modded car, it makes it unique, SWEET! build man keep the pics coming makes guys like me drool lol
Old Aug 13, 2010 | 10:35 PM
  #54
Andrew91GT's Avatar
Car: 1990 formula
Got some more done, thought I'd post up some more pics.
Pistons, rings, tools, etc.
Assembled piston on rod. Arias pistons, oliver rods with ARP 5.3 bolts
Piston in the block, cam installed
Cam card
Installing the balancer
Degreeing the cam
Checking piston to valve clearance - valves barely hit the clay.
Ready for the other 7 pistons
Old Aug 22, 2010 | 06:33 PM
  #55
Andrew91GT's Avatar
Car: 1990 formula
Checking rod bolt stretch, aiming for .0058"-.0062". This one didn't quite make it, had to back it off and out a little more on it the next time.
Oilpan on. Block has external oil return for less windage losses. Turbo oil return on the side of the pan as well as and the external pump feed.
Old Aug 26, 2010 | 09:11 PM
  #56
Andrew91GT's Avatar
Car: 1990 formula
Put the heads on tonight.
Cometic head gaskets. Only the top set of water holes are used, I plugged the block on the bottom row. Make sure you check the rivet locations to make sure they don't hit the block, I had to remove the rear passenger side rivet on my setup.
First pass with rustoleum chrome paint.
Second pass with copper coat.
Heads torqued down! Note the adapter plates bolted to the front and back of the valley rails. They are needed because of the raised intake ports on these heads so the intake will seal.
Old Aug 28, 2010 | 09:32 AM
  #57
Andrew91GT's Avatar
Car: 1990 formula
Got a couple mockup pics with everything there... ported super victor intake, 90mm throttle body and elbow, 1 7/8" x 3" stainless turbo headers, distributor.
Old Aug 28, 2010 | 11:42 AM
  #58
Awesome-X's Avatar
Car: 87 Camaro
Ugh. I want it. Send it my way
Old Sep 5, 2010 | 09:34 PM
  #59
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
looks great!
Im actually in the process of throwing a 521 BBF into my 1987 formula 350.
Ive had to do a ton of fab tho... the BBF is a long motha! Your build is alittle crazier than mine to... mines a simple 521, 10.5:1 compression, MAHLE forged flat tops, Eagle Hbeam rods, eagle crank, lunati 240/246 cam with .600 lift. Looking for eldelbrock RPM heads with 95cc chambers. Ive got a professional products balancer, procomp aluminum water pump, recurved duraspark, MSD street fire box, ford racing swap rear sump oil pan with pickup and high volume pump. But ive got the C6 to rebuild and lots of fabbing done.
I had to move the motor mounts back 3" to the firewall, then fab up my own motor mounts (block side) for another 1/2" of offset to push the motor back. (this is bc the crank snout is so long on the BBF that the balancer/crank would hit the wonderbar/front sway bar) I then had to clearance the firewall a whole bunch to clear the trans/back of the block. Im still in the process of relocating the gas pedal. But i just got the radiator done... i had to use a summit universal ford rad 31x19, but do to the lower driver side inlet and the power steering box I had to relocate the radiator down 2" and push it into the pass side front subframe about 2". With all that done it should just drop right in lol.
Interesting to see when u start to try and make it fit and how your going to get around most of this. post pics, ill start making my thread soon as well but i wanted to get some work done on it first. glad to see im not the only one!
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
