Engine swap noob questions
Old Sep 5, 2010 | 03:41 PM
mm1493's Avatar
I own an 82 Camaro, 305 4 Barrel (lg4). my friend has a 400 sbc that was rebuilt 10k miles ago, and has a lot of good parts. He would give it to me for free! How hard would this swap be? Would it bolt right in? Could I use a TH350 with this engine?
Sorry for the ignorant questions....
Old Sep 6, 2010 | 12:06 AM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
Re: Engine swap noob questions
no ignorant questions its how you learn,but yes it will fit right in cuz it is still a small block and you can use all the pullys that are on the 305 and its not hard will take about a day if you know what you are doin disconnect the wires and label them then unbolt the tranny and the engine mounts and make sure the grounds are off the engine along with the starter wires, also drain your coolant disconnect the houses and fuel lines and pull her out now do all that in reverse for the 400 lol and yes it will bolt up to a th350 im assuming that is whatyou have in the car if not then u will need a way of mounting a torque arm..one of the sponser sites(cant remember what one) makes a mounting bracket for the tranny
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
