T5 swap
Old Sep 27, 2001 | 11:03 PM
HrdRockA4305's Avatar
T5 swap
Ok, my evil plot to put a T5 in my car has taken yet another turn. I have found a new possible donor, this time a 85 trans am. He just built a carb'd vortech 350 and wants a muncie 4 speed to back it up, and will sell me the just rebuilt two or so months ago T5.
So anyway, what i was wondering is:
What parts would i need to pirate? (besides the obvious)
Would i need a new driveshaft?
Would the PROM need to be altered?
I know, not a real specific question, I've also posted this in the tranny board. But thanks up front to anyone with words of wisdom.
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/123,XXX miles
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
Old Sep 28, 2001 | 02:45 PM
David Petersen's Avatar
I have just done one of these swaps. The drive shaft will fit. As my car won't be running untill this weekened I am not 100% about the eprom but my reaserch has turned up that it should work fine. The starter for the auto is larger and won't fit into the T-5 bell houseing. You will have to rewire the switch that is attached to the auto shifter. You will need a switch and plug for the starter connetct on the clutch pedal and the wires will reach (with some creativity) to the pedal. I also drilled a small hole and just ran the backup switch through the floor to the T-5 tranny. Just a few things that weren't obvious to me. Hope this helps.
Old Sep 29, 2001 | 01:06 AM
Yeah, thats exactly the kind of thing i was hoping to find out, thanks man. I'm still not 100% sure i'm gonna do this though. What i really wanna do is the 5 speed thing then convert to TPI (I have an entire system located), but then i got to thinking, for the amount of $$ and time/work it'd take, i could just sell my car and find one that already has the TPI/5 speed 305 or the L98 auto. I dunno yet, depends on the money situation next year.
Old Sep 30, 2001 | 02:55 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
here's my recipe and it is quite a p.i.t.a if the engne is in.take out the console first and formost do the wiring first that way when the tranny slips in it's ready to go.the black control box for the shifter wll have to come out,next the two reverse wires will have to be cut and extended to the tranny also there is a nuetral safety switch purple and yellow hat will have to be cut and extended or wired together depending if you want a the neutral safety switch on the pedals to work i just wired mine together. make sure the trans s in neutral or push the clutch in every time you want to start it.as for the starter it's the same size they only made one size for the 3rd gen.you'll need a template for the slave cylinder hole i used a 2 1/4 hole saw bit the actuating assembly can be put in but requires lots of twists and turns to get it in also do it from underneath.you'll also need the tourqe arm mount from a t-5 the auto's different as well as the exhaust hanger but the auto's will work.drive shaft is the same,and the auto prom will work fine.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
