302 miniram?
Old Sep 26, 2001 | 03:18 PM
quickTPI305's Avatar
302 miniram?
i'm thinking of dripping in a 302 miniram into my 86 iroc. i've started to port and siamese my intake, so it should be between a tpi and a miniram. I was wondering if any had any suggestions or ideas.
1986 Iroc:
accel super stock wires
accel HEI super coil
B&M shift kit
ADS super chip
gutted airbox
MAF screens removed
upgrades in progress:
ported intake
crane cam
fuel pressure regulator
Old Sep 26, 2001 | 07:50 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Miniram usually requires lots of cubic inches, like 350 or better.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Sep 28, 2001 | 10:47 AM
mat89RS's Avatar
Correct me if I'm wrong but 302 produce HP in high RPM. Miniram are for low rpm HP. I'm not sure this setup would not work fine since the motor is made to run a carb unit.
LT1 POWERED
HEADMANS HEADERS
NEARLY 300 HP.
EATS MUSTANGS FOR BREAKFAST
Old Sep 28, 2001 | 01:22 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Actually miniram is for higher RPM operation. The medium-sized short runners are optimized for this as opposed to the small-sized long runners which are tuned for low-RPM operation.
Old Sep 28, 2001 | 03:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If I had a 302 and was going to spend that kind of money on a fuel injection system for it, I believe I'd put the Accel ProRam on it... looks like an altogether better match to a 302. I've worked with one of those on a 434 before, it's really sweet.
ICON Motorsports
Old Sep 29, 2001 | 07:57 AM
ede's Avatar
ede
if you have a real 302 (dz or cn i think) i'd sell it to someone that needed a 302 for a Z/28 and buy a bigger inch engine.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 29, 2001 | 10:06 PM
Tas's Avatar
Tas
you can make a 302 with a small journal 327 block and small journal 283 crank. Or with a single piece rear main seal 350 block and a L99(265cid 4.3L v8) crank. The L99 was the baby LT1 put in the Caprice. Use the long L99 rods with LT1/LT4 pistons.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Oct 1, 2001 | 12:24 AM
Fastcamaro87's Avatar
I think with the Mini Ram`s high RPM horsepower capabilities, and the 302`s as well, i cant think of any reason this wouldnt be a good idea.
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
gixxer92
Apr 12, 2022 12:09 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
BWilcox
Sep 20, 2015 12:19 PM
Mutillator
Sep 17, 2015 04:38 PM
Reborn756
Sep 4, 2015 03:42 AM
