Car has 350 Been sitting for 4 years.
Old Sep 28, 2001 | 12:05 AM
JMBoriss's Avatar
I bought a 84 firebird SE that has a SBC 350 750 CFM carb and busted 700r4 tranny. It's been sitting for 4 years doesn't run. I want to know what should I do to get it up to new. I already have a new 700r4 from an 87 GTA. The guy said it would run with the new tranny. What should I do to get all the "bugs" out? Take the engine out? Hone? Anything you guys would do? Thanks,
Jon If you want to email me more detail JMBORISS@YAHOO.COM
Old Sep 28, 2001 | 01:02 AM
Guest
Guest
Posts: n/a
I wouldnt worry about the engine, just change the fluids and do a complete tune up and it should be fine. I would be worried about the fuel system though, the rubber lines could be cracked, the fuel in the tank if there is any is probably a thick sludge by now, and that is something you will want to try and clean out before it becomes a real problem.
Cleaning out the carb and rebuilding it might not be a bad idea either.
[This message has been edited by madmax (edited September 27, 2001).]
Old Sep 29, 2001 | 12:52 AM
JMBoriss's Avatar
So How would I go about getting all the sludge out of the gas tank? Thanks.
Old Oct 1, 2001 | 03:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
My car sat for four years without running, outside, with four season changes every year. It had about 1/8 tank of gas in it. I just topped it off to dilute the old stuff, and it has been fine. I did, however, change the fuel filter after the first couple of tankfuls, just to be sure. That was two years ago.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Oct 2, 2001 | 07:42 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Usually if your going to store an engine for 4 years or so you do stuff to it like shoot oil into the cylinders and turn the motor over w/out firing it up so that the walls get coated with oil and so on.
Once I let a 350 sit outside for about 2 years. It started and ran OK but the next day when I tried to start it again it was siezed solid. I ended up just scrapping the car and I don't know for sure if the seizing had anything to do with the storage but the motor ran fine before I put it away and I just figured I should have stored it properly because that's what I've always been told to do.
I'm not a mechanic and other people's experiance seems to be different but I'd want have look inside before starting yours up.
I was going faster than I'd ever gone before but then I fell off.
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
milk
Aug 10, 2015 06:26 PM
