how accurate is dyno 2000???
Old Oct 4, 2001 | 09:39 PM
383strkr84z's Avatar
Should I trust this program or not?? It's Obviously fly wheel horse power, but can anyone confirm the accuracy of it??
Old Oct 4, 2001 | 09:49 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you feed it all the correct info as I have on several projects you would be amazed how close it actually comes. After drawing up and putting the actual engines in the car and running them on a chasiss dyno I came within 5-10 hp. but the tq. was quite a ways off.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Oct 5, 2001 | 02:39 AM
EvilCartman's Avatar
Car: '82 Z28
Were the torque numbers higher or lower on the chasiss dyno compaired to what the program came up with? Right now I've got a 350 setup in Desktop Dyno that does 529 hp at 6500 rpm and 465 tq at 5500 rpm.
Old Oct 5, 2001 | 02:44 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The torque numbers in lower rpm ranges are highly inflated by DD.
Old Oct 5, 2001 | 07:48 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
I have to agree, the horsepower figures are reasonable, but will lie to you if you lie about the figures (err on the conservative side), but the torque figues are way too enthusiastic at lower rpms.
Cheers
Richard
Fireslash
Apr 11, 2016 06:43 PM
kammi10
Nov 9, 2015 08:28 PM
LT1Formula
Oct 8, 2015 08:34 PM
ULTM8Z
Oct 2, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
