Wanna Build a ZZ430 (430HP)
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
you might want to check these guys out first... http://www.goautocenter.com/fast_burn__zz430.htm
92RS
92RS
Sallee Chevrolet has been building a clone ZZ430 for some time now. Click Here. They also are building a stroker version of it Here.
TABLE SAWS SUCK!!
TABLE SAWS SUCK!!
Car: '82 Z28
I'm building up a 520 hp 350 for around 2,800 - 3,000 bucks. Guess it helps that I got the long block for 50 bucks hehehe pulled from a truck.
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
has anyone thought of using the 383 crate engine.i can pick one up for like 2600,rip off those vortecs,slap on the fast burns and add an lt4 hot cam all for around 3800 what kinda numbers do you guys see for this package?as far as i know they dont offer the engine as a shortblock yet!but a 4.00 bore and a 3.80 stroke wth some good heads and a cam should be good for 400 easy(IMO).
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
best e/t:
Mongoose462ci
Sep 16, 2015 11:46 PM
