3800 series 2 Supercharged V6 In a 3rd Gen?
Old Feb 13, 2010 | 10:54 AM
relic87239's Avatar
Car: 1988 Chevrolet Camaro
Engine: In the market
Axle/Gears: 2.77
I was just wondering the details on a swap like this and the pros and cons. Is it even worth it? What transmission? Same motor mounts as a GN v6?
Old Feb 13, 2010 | 04:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 3800 series 2 Supercharged V6 In a 3rd Gen?
Pros: More power with better mileage than most V8s.
Cons: Leaks engine oil onto the exhaust manifolds and starts fires. Also leaks engine coolant into the engine oil because of intake manifold and gasket problems.
Shall I say more?
Old Feb 14, 2010 | 11:35 AM
relic87239's Avatar
Axle/Gears: 2.77
Good info. Im asking because I found a used motor with wire harness and ecm for 400. Has decent miles as well. i want to swap a LQ4 but obviously that would cost a lot more than 400 dollars. What transmission could be used?
Old Feb 14, 2010 | 12:52 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
since it's a FWD engine the starter is probably on the drivers side of the block. You would need to use a trans from a 3800 4th gen Fbody, 98 or newer. Motor mounts will be different than the old 3.8 RWD blocks.
You do know that the throttle body will be aimed directly at the firewall right?
you are going to spend a lot more than $400 to get this to work, chances are that it's oil pan won't clear the Fbody cross member. You'll either have to modify it or pick up a tubular crossmember.
Old Feb 20, 2010 | 06:12 PM
relic87239's Avatar
Axle/Gears: 2.77
ok good info, the price is great but you are right it would probably cost too much. I was just curious.
Old Feb 20, 2010 | 06:32 PM
duffer26's Avatar
Car: 92 RS
Transmission: auto
put the intake on backwards then the TB is foward and the top hose is on the front of the motor then make a side shaft drive for the charger
ala calaway
http://www.youtube.com/watch?v=9XMWpUNm2wE
had my fair shair of fun with the sc'd 3800
http://smg.photobucket.com/albums/v517/duffer26/SSEi/
AussiePr0nCar
Mar 6, 2020 04:04 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
