377 build up
Old Oct 20, 2001 | 10:06 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
377 build up
I ran across a 377 buildup ( 400 cu.in block bored .30 with 350 crank) but didnt get all the info.. I know theyre hi-rev engines..
What exactly do I have to do to assemble one ? Are forged parts necessery ?
Thx 4 the info (if there is any lol)
Old Oct 21, 2001 | 12:23 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Forged pistons should be used but lower cost pistons will work also. all the fasteners should be good aftermarket like ARP etc.
To put a 350 crank into a 400 block special bearing spacers are required since the mains in the 400 block are larger.
These engines are designed for high rpm HP but with only the stroke of a 350, don't produce as much low end torque as a 400. A typical race 377 starts building power above 4000 rpm. A street engine usually tops out around 5000 rpm.
The 377 makes a good race engine for drag or oval track but I wouldn't suggest one for use on the street. Build a 350, 383 or 400 instead.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Oct 21, 2001 | 03:59 AM
Spectre's Avatar
Engine: 3.0L/183
Hmm, i suppose ur right...
Ill keep looking for a nice build up
thx
Old Oct 21, 2001 | 11:17 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
do a 406 you'll get the most grunt for the least money.
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
