Hi i want to do this motor swap from an 84 firebird with a 305 and a t-5 five speed to a tpi 350 camaro engine. is it feasable or what. what do i need to change to make it work and is it worth the time and trouble. please someone tell me i need to know.thanks
Well, just be glad it's a V8 T-5. Yes, it'll work. I've bolted a V6 T-5 up a V8 engine and tore it apart.
And, your's is a V8 car so that will make it even easier. So see, you're going from V8 to V8 and not V6 to V8 like I did. It'll go well.
1984 Firebird SE
1985 Camaro z28 305 engine T-5 Five Speed Tranny Performer Intake, Accel Distributor, Raceing Starter, 650 CFM Carb, .488 Lift Cam, Dual Exhaust.
92 Camaro Leather Seats Console, carpet everything. Soon to put in 700R4 and 427CI. (Hopefully)
And, your's is a V8 car so that will make it even easier. So see, you're going from V8 to V8 and not V6 to V8 like I did. It'll go well.------------------
1984 Firebird SE
A friend of mine did that swap in his 305 t-5 camaro. He used the painless wiring harness and found an aftermarket fuel pump that didn't have to go in the tank. That made it a lot easier since the harness comes with instructions and he didn't have to drop the tank.
