rear end
Old Oct 30, 2001 | 01:00 AM
PimpCamaroRS's Avatar
rear end
i have a 91 RS 305tbi and plan on dropping in a SBC 400(probably bored to 406) with comp cams, nice heads, headers and all the goodies.....with all this new horse power and torque i know my stock rear end will snap like a twig. is there any thing i can do to build up my rear end in a cheap way b/c money is an issue.
whose down with a little rice rocket beat down?
Old Oct 30, 2001 | 07:29 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
A good 9 bolt will probably work fine and it's about 1/2 the price of a 9 inch or 12 bolt.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
Old Oct 30, 2001 | 08:30 AM
do i just buy a new rear end or can i upgrade mine.if i do buy a new one where can i buy a good 9 bolt and how would iknow if it is good or not
Old Oct 30, 2001 | 01:50 PM
SoCo80p's Avatar
things you can do are (givin its the 7.5 10 bolt, i dont think you can even get any of the folowing parts for a 9 bolt) get some moser or strange axles (about 250$) mabey and auburn or eaton posi (400$ or so) and some gears are another 150 or so so to deck out that axle your in the 800$ range and a nice 12 bolt is around 1,100 or so, but if your not going to be running slicks the axle you have now should be allright.
Old Oct 30, 2001 | 02:35 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">i dont think you can even get any of the folowing parts for a 9 bolt)</font>
Maybe you should do some research before saying things like that. Then you will realize that aftermarket axles, gear sets to 4.10 ratios and new posi carriers ARE available for the 9 bolt.
<font face="Verdana, Arial" size="2">so to deck out that axle your in the 800$ range and a nice 12 bolt is around 1,100 or so</font>
If you can get a complete bolt in ready to roll (brakes and all) for $1100, I'll take two right now! A complete 12 bolt or 9 inch will be double that.
Miles
88 427 Big Block Camaro
Updated 1/8 10/21/01 7.76 @ 94mph 1.72 60ft
www.koolmeister.com
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
