383 Build--need help choosing
Old Feb 20, 2010 | 11:59 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
This would be my first build for my 1982 Camaro Z28. I'm building this pro-street but the most HP I can get.
Here a list of part I'll be buying in the next couple of months for the new motor.
- 350 4 bolt main .30 over
- 383 Stroke Kit from Powerhouse
- 195 AFR Heads
- 4 speed t-10
- 800 CFM thunder series Edelbrock
- RPM air gap intake manifold
- I'm going to go with the Comp Cam XR288HR Duration 288/294, Lift .520/.540
- The max lift on the AFR heads are 600 so I was thinking about going with 1.6 rock arms?
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
