quick question regarding LT1 swap
Old Nov 11, 2001 | 07:53 PM
Rokshocka's Avatar
i heard about something concerning a security system and VATS... and someone said i need to buy a new VATS chip and module, wat is it? and do i need it? i dont want to worry about any security system right now, i just wanna get the swap figued out lol
and one more thing, people say they used hedman headers with an LT1, does anyone have any part #'s as to which you used?
thanks
Old Nov 11, 2001 | 10:48 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Any thirdgen headers can be used when an LT1 is in a thirdgen. About the VATS, you can get it programmed out of the computer so you won't have to worry about it.
Old Nov 12, 2001 | 09:49 AM
FiReBReTHa's Avatar
i was told only slp headers, and that a painless wiring harness can help with the vats, and wiring up...
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Nov 12, 2001 | 10:26 AM
Rokshocka's Avatar
i was told that some headers dont clear the ports... and only SL and hedman do, and i heard of the pailess stuff, any part#'s ad such that i should knowof? thanx
Old Nov 12, 2001 | 12:37 PM
mat89RS's Avatar
Here I am at youtr rescue !!!
about the vats well it depends , if you are using the original wiring harness like I did it would be better to use the vats module that came with it and find the correct value of the pellet resistor in the key of the orignal car that had that motor in. if you're going with painless well you can use the old ECM if it's a 92-94, if it's above those year, you are screwed, you'll have to buy the painless then a new ECM or Chip without VATS.
the best way to do it is to keep all the orinigal wiring of the donor car and simply hook it up to your wiring ...it's not easy but it's not hard.
about the header i' used headman's header.... fairly easy to install and work great with the LT1.
Let me tell you that stang will get a kick in the *** after that swap.
seeya
LT1 POWERED
HEADMANS HEADERS
300 HP backed with a limited slip, 2.73.
Top speed reached: 150 mph
EATS MUSTANGS FOR BREAKFAST
Old Nov 12, 2001 | 03:03 PM
Rokshocka's Avatar
i saw that jegs or summit sells 2 sets of hedman headers for 82 to 92 camaros, ones with a y pipe and 1 5/8" primaries, the others have stepped primaries from 1.5" to 1 5/8" ... which ones did you use? part #'available? thanks
Old Nov 12, 2001 | 11:17 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
I'm using Hooker Long Tube headers so far with no problems on my LT1.
Old Nov 13, 2001 | 03:24 PM
mat89RS's Avatar
I'm using the 1 5/8" I don't have the part number because I did a trade... my BBQ versus 1 set of headers and y-pipe !!!
LT1 POWERED
HEADMANS HEADERS
Old Nov 13, 2001 | 03:25 PM
mat89RS's Avatar
LT1 POWERED
HEADMANS HEADERS
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
sreZ28
Aug 14, 2015 07:48 PM
jahblah
Aug 12, 2015 05:54 PM
