355= NO POWER...WHAT IS GOING ON?
Old Feb 27, 2010 | 08:33 PM
jls172008's Avatar
OK, I HAVE A 90S MODEL GM CRATE MOTOR THAT HAS BEEN COMPLETLY REBUILT, HERE IS A LIST OF THE MODS
7QT OIL PAN
HIGH FLOW OIL PUMP
CRANK WAS TURNED
BORED .30 OVER
FLAT TOP PISTONS
COMP CAM 268
STOCK 993 CASTING HEADS
EDLEBROCK PERFORMER 2101 INTAKE
HOLLY 600 DP
HEADMAN HEADERS
HEI 65000 VT DIST.
8.8 WIRES
ACCEL PLUGS
MSD 6AL
FLEX A LITE DUAL COOLING FANS
DBL ROLLER TIMING SET
OK NOW THE PROBLEM. I HAVE BEEN TOLD THAT IT SHOULD BE MAKING AROUND 310 OR SO HP AND ABOUT 370 TQ. THERE IS NOW WAY THAT IT IS MAKING IT THOUGH. ME AND MY BUDDY RACED IT AND MY MOMS GRAND AM AND IT LOST!!! LOL BUT ANYWAYS THE CAR (85 TA) SEEMS TO LOOSE ALL POWER WHEN IT HITS SECOND GEAR. I HAVE BEEN TOLD THAT THE TIMING IS OFF SO I AM GOIN TO ADJUST IT BUT I REALLY DONT KNOW HOW IT SHOULD BE SET, ANY IDEAS? BUT MOST OF ALL IM TRYING TO FIGURE OUT WHY THIS CAR HAS NOT GOT THE POWER THAT IT SHOULD HAVE. ANY IDEAS ON WHAT IS GOING ON?
Old Feb 27, 2010 | 08:55 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: 355= NO POWER...WHAT IS GOING ON?
Honestly timing can hurt performance ALOT if its set incorrectly. You need to get a timing light.
Old Feb 27, 2010 | 09:59 PM
jls172008's Avatar
THE PROBLEM IS I DONT KNOW WHAT TO SET THE TIMING AT
Old Feb 27, 2010 | 10:04 PM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
id check timing first, i had a similar problem once and it was the curve kit in the distributer, theres at least 3 different size springs
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
That could be a problem..
Old Feb 27, 2010 | 10:09 PM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Axle/Gears: factory
id get a hold of comp cams and see what they recommend timing at
Old Feb 27, 2010 | 11:02 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Total timing should be between 34 36 degrees
Old Feb 27, 2010 | 11:06 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Also if this was just installed you might want to check the little things. Things like make sure all vacuum lines are connected and none leaking. check firing order to make sure its right, also check to make sure the butterflies in the carb are opening all the way when the pedal is to the floor.
Old Feb 27, 2010 | 11:10 PM
jls172008's Avatar
i have gone over it and everything seems to be working properly i will try to get it timed tomoro...can someone explain the process i know its simple i have never messed with timing before
Old Feb 27, 2010 | 11:19 PM
jls172008's Avatar
and befor i set the timing i have to get the tach working it hasent worked since i got the car, the wire is hooked up but nothing, any ideas?
Old Feb 28, 2010 | 12:09 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
To set the timing:
Disconnect and plug the vacuum advance.
Loosen the distributor clamp so you can just turn the distributor by hand.
With the engine idling, move the distributor until you have 12 degrees before top dead center.
Tighten the distributor clamp and verify the timing didn't change.
Reattach the vacuum advance.
Old Feb 28, 2010 | 12:21 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Originally Posted by five7kid
To set the timing:
Its actually very easy
I also have the Comp 268 its a good cam for street. Anyway 12-15 advanced is what I run it at and its got plenty of power.
I did have a problem with it loosing ALOT of power due to the cam gear jumping a tooth on the chain (thats what i get for not putting a new chain in when i put the cam in) that caused the timing to retard quite a bit so i put a new double roller set in and set it at 12-15 advanced and it ran like a champ.
I'm sure the timing is your issue.
Old Feb 28, 2010 | 12:39 AM
jls172008's Avatar
sounds like a good project for monday lol i will let you know how it turns out
Old Mar 1, 2010 | 03:37 PM
bigzeke's Avatar
it amazes me that this kid seems as if he needs help with timing and everyones going use a timing light look lets start with the basics ok it is obvious you havae a timing woe here is what you do 1. pull no 1 plug out that will be on the driver side frt 3. remove dist cap and pay attention to the angle of the rotor button it needs to be pointing directy to that cylinder if it is not loosen the hold down clamp and reset it 2. rotate engine until piston is at tdc = top dead center ,if you dont have a piston stop then use a screwdriver pay attention to the reference mark on your balancer it should be on the money 4. when you set dist down wire it up clockwise 18436572 then adjust from there see how this does and i will check back later there are some wonderful websites that can explain how to use a timing light if you are not familiar...............birdman
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mike22115
Sep 28, 2015 04:49 AM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
