proper fuel pump for my application?
Old Mar 1, 2010 | 07:35 PM
crystal383's Avatar
i'm building a 383 for my 1987 camaro. i'm running dart iron eagle 230cc heads and a holley proform 750 carb.
i want to know what the best fuel pump to use would be? how many gph?
i figured an external fuel pump would be easier to work with than an in-tank.
i'm on a budget. i came across this one from jegs
http://www.jegs.com/i/JEGS/555/15913/10002/-1
Old Mar 1, 2010 | 08:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That would probably work, but you would still need to drop the tank and remove the existing in-tank electric pump.
Old Mar 1, 2010 | 10:50 PM
crystal383's Avatar
re: proper fuel pump for my application?
thanks. i'll go ahead and purchase it.
and how difficult is it to drop?
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Be looking at more like this:
http://www.jegs.com/i/Holley/510/12-125/10002/-1
I had a holley black pump, which is rated higher than the jegs brand pump you posted and it wouldn't keep up with my 355 vortec head combo at the top of 3rd. So IMO I'd get the one listed above or similar.
Old Mar 2, 2010 | 09:31 AM
crystal383's Avatar
the one you listed looks really nice, but it said it only flowed 110 gph while the jegs one i posted flowed 130 gph. will that difference in flow rate not really matter?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
