330HP Gm crate engine...
Old Nov 30, 2001 | 06:04 PM
82T/A powah's Avatar
hey i was thinking about swaping my tired 305 for this 330HP 350 engine that gm offers, has anyone heard stuff about it? is it just another over rated horsepower engine that gm put out? also i had baught a 570CFM carb by holley a while back, it is the street avenger version.. will this now not be a good size carb for the engine? please input what you guys think..
thanks
Old Nov 30, 2001 | 06:16 PM
BTW here's a link to the webpage for basic spec's on it.. this is the deluxe version which just has a carb and stuff on it, but the specs are pretty much the same as the other 350 HO..
https://www.spoperformanceparts.com/...102&CATID=1099
Old Nov 30, 2001 | 06:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It is discussed at length on the swap, tech, and aftermarket forums. Do you understand what Vortec heads are? They have their limitation and problems. This thread https://www.thirdgen.org/messgboard/...ML/002254.html is an example of both the discussion of the engine that takes place and the issues with it.
It's an okay choice if you don't have emissions to worry about. Did you read this part? "This engine is perfect for your 1975 or older vehicle or any off-road usage."
The 600 Holley they put on it is pretty small. Your 570 would be even worse.
I don't mean to be a wet blanket, but you need to understand what you'd be getting.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
RedLeader289
May 28, 2019 01:47 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
Giocio
Oct 1, 2015 12:20 PM
RedLeader289
Sep 23, 2015 06:50 AM
jbm379
South Central Region
Sep 15, 2015 09:13 PM
