swapping carb'd to tbi
Car: 82camaroz28,83camaroz28,88iroc-z350
Engine: 305 carb,305 carb, 355 lt1 tpi
Transmission: t5, 700r4, m21 muncie
Axle/Gears: 2.27
im thinking of doing this swap and i dont know if you have to switch the heads for tbi
thanks
thanks
Transmission: 4L80E/4L80E
'86-earlier heads have the center two intake mount bolt holes on each side at the same angle as the rest of the bolts, while '87-up those 4 bolts are at a different angle.
Other than that, no problem putting a TBI intake on heads that are on an originally carb'd engine.
