350 swap into 84 h.o. t/a
Old Dec 4, 2001 | 02:58 PM
batmanta01's Avatar
Car: 91 GTA, 95 T/A, 80 FIREBIRD
Engine: 350, 350, 305
Transmission: 700R4, T-56, TURBO 350
What would I need to legally swap a 350 into a 84 H.O. t/a and still pass Cali. emissions?
Old Dec 4, 2001 | 03:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are two types of "legal": "Technically" legal, and "for all practical purposes" legal.
For "technically" legal, the only with-factory-sticker choice is the HO 350 Conversion kit from GM. That assumes you have a carb'd engine and automatic transmission. It'll run you about $4400 plus tax and shipping (installation book included, but not installation).
Although I left California 7 years ago, I understand you can go through a referee process to certify something that wasn't offered by the factory. This assumes that you have something that was certified by the factory in something else, and you have all of the equipment it had. (I may be a little off with this description - perhaps Engineboy will correct inaccuracies.)
Then there's "for all practical purposes" legal. That means you put a 350 in where the 305 is now, putting everything back on that the 305 had so you can pass the visual. You keep cam and heads selection reasonable so you don't fail the sniffer. The only things you change are those that are CARB certified or exempt, such as headers. If/when they ask you what size engine you have, you simply point to the underhood sticker and let them read it.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Frozer!!!
Jan 19, 2024 04:55 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
