Dyno numbers
Old Dec 2, 2001 | 09:01 AM
Z28DJP1987's Avatar
Dyno numbers
Anyone Dyno their cars after swapping engines
such as 350ho, zz4 and etc. Lets see some posts with the results.
Old Dec 2, 2001 | 04:36 PM
Z28DJP1987's Avatar
All these engine swaps and no one has Dyno'd
their cars to check RWHP. I bet Kevin 91z
can show us what his car Dyno'd at.
Anyone....
[This message has been edited by Z28DJP1987 (edited December 02, 2001).]
Old Dec 3, 2001 | 08:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I had my 305 dyno'ed, but I personally don't consider it to qualify as a "swap". It's the original L69 block with different heads, a roller cam, TES, and most everything else (carb, intake, exhaust, air cleaner, all emissions stuff operating) exactly as it came stock. As a brand-new motor, with 8 miles on it, it passed CA emissions a few days before it went to the dyno.
It peaked at 214 RW HP @ 4500 RPM and 282 RW ft-lbs @3300 RPM, which works out to about 260 or 265 crank HP peak.
ICON Motorsports
Old Dec 3, 2001 | 04:41 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
OK, I was able to have my new 350 dyno'ed before putting it in, but I haven't had it on a chassis dyno since it's been in the car.
With the chip I have in the car and same TBI setup my 350 put out 417 ft/lb at 2500 and 312 HP at 5000 RPM.
This is with SLP 1-5/8 Headers and a single Flowmaster 3" 2 Chamber muffler,The custom Fastchip Prom and fuel pressure at about 20PSI.
-Rich-
Old Dec 4, 2001 | 01:52 PM
Z28DJP1987's Avatar
Well here are my numbers, I guess no one else
swapped a engine and had it Dyno'd. Made the swap in April 2001.
1987 Black Camaro IROC-Z (original owner) Replaced LB9 @ 86100 miles.
New 350 Crate engine
Balanced & blueprinted
World Prod SR 67cc Heads 9.6:1 C.R.
Cam: 454lift,216dur@50,110ls
TPI Induction(from 305)
22# Fuel Injectors
AFPR & Gauge
SLP Intake runners
Fastchip stage 2 chip
K&N filters & Air Foil
Hothkis STB
SLP 1 3/4 Headers
CATCO 3" Catalytic conv.
SLP 3" Cat Back Exhaust
700R4 Auto
SLP Torque Converter (2400 stall)
1LE Aluminum Dr Shaft
B-W 9 bolt rear 2:77 Possi. Four wheel disc brakes,245/45/ZR-17 Tires
17x8.5 ATI 5 Razze Wheels
Dyno results: 211 RWHP & 282 RWTQ.
271 HP & 362#/ft at flywheel with all Emission controls installed. New Toy!
Old Dec 4, 2001 | 07:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So my CC-carbed 305 runs with your TPI 350, żeh? Now I don't feel so bad for nutting my poor car. Still, you didn't do too bad, you got 50 HP or so extra out of it.
ICON Motorsports
Old Dec 4, 2001 | 07:20 PM
Z28DJP1987's Avatar
Thanks RB
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
