LG4 engines
Car: 06 Toyota Tundra SR5
LG4 engines
When I start from 0 mph, and wot, before it hits 2nd gear, the rpm's go up to only 3000 rpm, then switches gears around 40mph and barely catches 2nd gear rubber, then revs uip to 3200 and switches to 3rd at aroudn 60mph. Is that really poosy? If it is, is it because my engine is mainly stock?
87 FireBird Formula
305 4bbl LG4
K&N Filter
Flowmaster 80 Series
P215/65R15 Tires
Clarion ProAudio DB315 Deck
MTX Thunder6000's 12" subs
Jensen KA3 500 Watt Amp
Pioneer 6x9s Ts-A698
-----Need Upgrades-----
--Give suggestions plz--
http://members.tripod.co.uk/michigan34/car.html
87 FireBird Formula
305 4bbl LG4
K&N Filter
P215/65R15 Tires
Transmission: 4L80E/4L80E
I would suspect that the throttle valve cable is not properly adjusted. It should shift somewhere around 4800 rpm at WOT.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
